Hey guys,
Im going to get my suspension fitted early next week - got the whiteline f & r sway bars and front castor adjuster - what sort of settings should I say to them? Ive got the bilstein shocks and white line springs package already fitted - need these new mods to work well, car is used mainly on street but with track days around once a month.
Any suggestions?
Cheers!!
Chris
I'd start with soft/soft on the sway bars and work from there. If it under steers, tighten the rear. If it over steers tighten the front.
If you have a gtst then I'd go for as much caster as you can get without the tyres scrubbing when you turn the wheel. I go even side to side with no ill effects on the street.
yep. ask for max castor they can get. as for bars, me personally would start with front to full soft and rear to 1 step up from soft. :D
rear is a piece of cake to get to, just jack up the back and you're away.
Front requires removal of the wheels to get at the links easily (atleast in a 32) and it can be a little awkward getting the link in and out of the bar.
As the baron has eluded to, you'll probably find the car under steers with both bars at soft initially and so you will be tightening the rear up.
tyres - true! :laugh:
On the street, they hold well as for 1. I hardly take the car out and 2. no point pushing it too hard!
However I'll most likely be using those federals 595RS's which has been posted in this forum section!
Thanks again :)
Chris
done and done :(
Car feels fantastic!
They put the fronts on medium and rears on hard
and max castor
had to go through Galston Gorge (NSW people would know this road!) the other day - car never felt so alive!
Still going to take a bit of getting used to - as I did find, got on the gas a wee bit early and the rear stepped out - but that was silly anyway :ninja:
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
