Wbt: Bov Direct Bolt Onto Rb20det + Brake Line + Adjustable Castor Rods Front!
Hey guys as the title says im after a bov with a direct bolt on to a r32 rb20det i want that wont make the car stall as i have already changed BOV twice and still not happy. Updated see last post. after front brake line the little one next to the caliper and also adjustable castor rods
cheers
Title updated.
Edited by OnAhigh
Hey guys as the title says im after a bov with a direct bolt on to a r32 rb20det. Also after the front "S" badge which sits in the bonnet of a r32. let me know what you got. located in sydney
cheers
im finding it very hard to find one of these too... are they even manufactured?
I have a SARD R2D2 bov for sale, came off my RB20 but it didn't bolt where there standard bov did.
http://www.skylinesaustralia.com/forums/in...howtopic=156767
I can even supply a plate to blank off the standard bov :unsure:
I've got one, it's a little dodge looking...I can send some pics if you like. It's a Blitz DD copy with a flange welded onto it. A decent gasket on it and it'd work sweet....was designed for return but can supply the vent filter with it which will make it look better.
I've currently got 2 bovs, ones a HKS SSQ and the others a APexi twinchamber, the twinchamber is currenlty on its way from japan, both replace the factory bov, haven't decided which 1 i want to use on my car, pm me an offer for 1 n i may consider selling 1
  • 5 weeks later...
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
