Wbt: Bov Direct Bolt Onto Rb20det + Brake Line + Adjustable Castor Rods Front!
Hey guys as the title says im after a bov with a direct bolt on to a r32 rb20det i want that wont make the car stall as i have already changed BOV twice and still not happy. Updated see last post. after front brake line the little one next to the caliper and also adjustable castor rods
cheers
Title updated.
Edited by OnAhigh
Hey guys as the title says im after a bov with a direct bolt on to a r32 rb20det. Also after the front "S" badge which sits in the bonnet of a r32. let me know what you got. located in sydney
cheers
im finding it very hard to find one of these too... are they even manufactured?
I have a SARD R2D2 bov for sale, came off my RB20 but it didn't bolt where there standard bov did.
http://www.skylinesaustralia.com/forums/in...howtopic=156767
I can even supply a plate to blank off the standard bov :unsure:
I've got one, it's a little dodge looking...I can send some pics if you like. It's a Blitz DD copy with a flange welded onto it. A decent gasket on it and it'd work sweet....was designed for return but can supply the vent filter with it which will make it look better.
I've currently got 2 bovs, ones a HKS SSQ and the others a APexi twinchamber, the twinchamber is currenlty on its way from japan, both replace the factory bov, haven't decided which 1 i want to use on my car, pm me an offer for 1 n i may consider selling 1
  • 5 weeks later...
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
