Wbt: Bov Direct Bolt Onto Rb20det + Brake Line + Adjustable Castor Rods Front!
Hey guys as the title says im after a bov with a direct bolt on to a r32 rb20det i want that wont make the car stall as i have already changed BOV twice and still not happy. Updated see last post. after front brake line the little one next to the caliper and also adjustable castor rods
cheers
Title updated.
Edited by OnAhigh
Hey guys as the title says im after a bov with a direct bolt on to a r32 rb20det. Also after the front "S" badge which sits in the bonnet of a r32. let me know what you got. located in sydney
cheers
im finding it very hard to find one of these too... are they even manufactured?
I have a SARD R2D2 bov for sale, came off my RB20 but it didn't bolt where there standard bov did.
http://www.skylinesaustralia.com/forums/in...howtopic=156767
I can even supply a plate to blank off the standard bov :unsure:
I've got one, it's a little dodge looking...I can send some pics if you like. It's a Blitz DD copy with a flange welded onto it. A decent gasket on it and it'd work sweet....was designed for return but can supply the vent filter with it which will make it look better.
I've currently got 2 bovs, ones a HKS SSQ and the others a APexi twinchamber, the twinchamber is currenlty on its way from japan, both replace the factory bov, haven't decided which 1 i want to use on my car, pm me an offer for 1 n i may consider selling 1
  • 5 weeks later...
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
