Payments cleared through for the following orders:
1. Midnight - for 909G R32 Gtst
2. Holes - for 7693S & 908S R33 set
3. GunMetalR33 - for 7693S R33 Gtst
4. slayer_1971 - for 7701S R32 GTR Vspec Brembo
5. My_Silvia - for 7693S R33 Gtst
6. krizza_ca18det - for 909S rotors
  • Replies 490
Posted Images
Not yet.
The list is building up a bit slower than I expected with only 6 cleared transfers & another 1 or 2 is waiting to clear through, so I will submit the whole thing this Friday. Depending on their stock level they may require 1 or 2 weeks to make the rotors, but in the past it had sometimes been as quick as a couple of days. The delivery itself would probably take a few business days, so it's making/slotting the rotors that takes most of the time.
If there's any delay I will let you guys know ASAP.
Cheers,
Rianto
im still keen on the normal rotors dude..
Will transfer the money in an hour when i get back home..
So you can add me to the list..
If its just normal rotors, will i get it quicker lol.. Coz i really need it asap..
Anyways will pm you now
Sidd.
7. hazerb30 - for 7926G & 908S rotors
8. racsov500 - for 909S rotors
9. siddr20 - for 908 plain rotors
Almost 10 people! Group Buy closing this friday so please order ASAP to avoid any delays.
10. chinkenboi - for 909S rotors
11. OnAhigh - for 909S rotors
Yep, but in the end even if it's less than 10 I will submit it anyhow.
I've just got another one person who might jump in and make it 12 persons.
Will sort it out tonight.
Anyone missing out on this one please hold off and I will advise when the next Group Buy is re-opening again.
We've got everyone's payments cleared through for the following orders:
12. JonesyGTR - for 7926G
Allright guys, I have submitted the bulk order on Friday night, I will advise as soon as I heard confirmation that they are processing the order. Hopefully I should hear something by end of today....
They have confirm receipt of the group order and is processing them right now. Some rotors will start to be delivered from tomorrow onwards, ETA would be either end of the week or sometime next week.
Also, I will be away (to NZ) on Thursday - Sunday so I will only be able to reply to your pm or queries today, until
tomorrow daytime, then after I am back on Monday next week.
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
