damn missed it. will there be another group buy in the near future??
chasing prices for slotted front and rear rotors for a r32 gtst
cheers,
mick
  • Replies 490
Posted Images
How can I tell which R34 rotors I have without taking off the rims and measuring them? Is it dependant on the year model?
Vidospace, my sources confirmed that the 7693S front rotors 296mm same as R33 will only fit R34 GT non turbo. For R34 GTT you will need the 310mm rotors which RDA is trying to get the exact measurement and trying to manufacture. So please stay tune as at this moment it's still too early for me to get pricing nor confirming whether the manufacturing process is worth the cost to do for our niche import market.
Yeah i think i may be in for the next need to confirm 2x front slotted rotors for S1 r33 price via pm if i can please delivered brisbane i lost the last pm from ya
Cheers A
All PMs sent.. Group Buy 11 actually has started last week and planning to submit the bulk order this coming Friday.
I had 2 confirmed orders already:
- black sky
- darkon
3. R33 GTS-t/R34 GT non turbo: F=7693S 296mm RRP $305, R=908S 297mm RRP $190
on thing im not sure about is the actual price we will be paying youve got RRP i assume thats if i go to a RDA seller?
DOH i re-read conditions of group buy again can i please have a PM of price for my eyes only thanks
Friday hey, sweet :D
should work well my motor just went back in so if i get the rotors some point next week it will work out well
cheers you'll definitely be getting a bloody damn positive trader rating :D
Edited by Darkon
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
