  • Replies 490
Posted Images
Got a couple more orders in...
- daemon667 for rear grooved & dimpled early R32 GTR
- SLVR32GTR for front slotted early R32 GTR
- hayden49 for full set R33 gtst slotted & EBC red pads
- carasky for R33 gtst front slotted
- wolls for EBC greenstuff pads
Its, woolls ebc redstuff pads Not green :P
Its, woolls ebc redstuff pads Not green ;)
Sorry for the nickname spelling. Correct it's redstuff pads I've got on my order list, just a typo on the forum thread.
Got 6 orders in now...
- woolls for EBC redstuff pads
- scooter_r33 for R33 gtst full slotted set.
whats the difference with redstuff greenstuff which is better for everyday driving with the occasional spirited drive
Hi Mate,
The greenstuff is rated at 600-ish deg C, while the redstuff is rated at around 750deg C.
Have a look at http://www.ebcbrakes.com/greenstuffinfo.html for greenstuff info, and
http://www.ebcbrakes.com/redstuffinfo.html for redstuff info on these pads.
The redstuff is made from the new 3000 series compound.
Some people who has used the redstuff likes them, for the price they gave value for money, and give better feel than the greenstuff. I had greenstuff when I had my R33, low dust, and good daily driving performance. For spirited street drive I'd recommend redstuff based on what people have told me regarding their first hand experiences.
Red should be enough for once in a while club track days (4-5 laps), and hill climb events. But if you're after more racing edge, e.g. for downhill race motorsport, then I can source you some yellow pads or even extreme blue racing pads, but these cost heaps and are R 'Racing' rated compound which RDA told me need to be warmed up a bit before you get optimum performance from it...
So IMHO I won't recommend it for street cars to use anything above redstuff, as they also cost more and probably overkill on most street cars.
Hope that helps...
yeah thanks heaps rs73
im upgrading from non turbo brakes on my R33 gts4 there are pads that came with the brakes but its now something i need to consider for when they wear out.
pm sent..
Update to order: 7 orders in now...
- Linden32 for R32 GTR front slotted (waiting clearance)
as above. Any update on when we can expect front sets for GT-T's?...
Nevermind :whistling: , I read back a page... 9 weeks aye?
Edited by Yo-Yo
All payment for these 7 orders are in:
- woolls for EBC redstuff pads --> upgrade to yellowstuff
For R34 GTT rotors I was told last week they're about 9 weeks away so this week should be about 8 weeks away.
n15m0 & Yo-Yo, if you can send me a pm with "RDA R34 GTT front rotors" in the subject, I will keep it in my inbox so as soon as they become available I can remember who inquired about it.
Updated: 9 orders now
- carasky for R33 gtst front & rear slotted
- P4t for R33 GTS4 AWD non turbo full set & pads
- bangahh for R33 Gtst front slotted (waiting payment clearance)
hey, just for mine you've got me as r33 non turbo its actually r32 gts4 and yes its turbo :P
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
