  • Replies 490
Posted Images
ok, I'll have to change that, and have to change the part no as well.
do you know if you're using the same rotor as the R32 Gts-t?
i was hoping you would know :) does that mean the price changes also?
I belive the R32 gts4 is same brake as the R32 gtst its only the R33 which has the 4 stud 280mm rotor the R32 should be 280mmFR 297mm Rear
P4t, the price changes, the rotors are cheaper but the pads increases a bit. I'll pm you with refunds due once i've calculated the difference. I just wanna make sure it's 5x114.3mm stud pattern as this GB 15 is closing tomorrow and I don't wanna send an order with the wrong part in it.
Batch 15 is closing now...
- daemon667 for rear grooved & dimpled early R32 GTR
- SLVR32GTR for front slotted early R32 GTR
- hayden49 for full set R33 gtst slotted & EBC red pads
- carasky for R33 gtst front & rear slotted
- woolls for EBC redstuff pads --> upgrade to yellowstuff
- scooter_r33 for R33 gtst full slotted set.
- Linden32 for R32 GTR front slotted
- P4t for R32 GTS4 AWD turbo full set & pads
- bangahh for R33 Gtst front slotted
- frankie60 for R32 GTR early slotted front rear
- madqrk for S14a 200SX slotted front rear
- Michael_1882 - R33 full set (to be confirmed)
- Nismo_S - RDA648S (to be confirmed)
No problems. Theo is that address you gave me your work address? Should I put a company name or just the Level & Street is fine?
Rianto - Although I've replied via PM I'll just reply via here too
If you could just address them to Theo Dinakis and the address I sent you in the PM that would be great. Our mail people here will sort it out and they'll get to me within the hour of them arriving :rofl:
Cheers,
Theo
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
