  • Replies 490
Posted Images
ok, I'll have to change that, and have to change the part no as well.
do you know if you're using the same rotor as the R32 Gts-t?
i was hoping you would know :) does that mean the price changes also?
I belive the R32 gts4 is same brake as the R32 gtst its only the R33 which has the 4 stud 280mm rotor the R32 should be 280mmFR 297mm Rear
P4t, the price changes, the rotors are cheaper but the pads increases a bit. I'll pm you with refunds due once i've calculated the difference. I just wanna make sure it's 5x114.3mm stud pattern as this GB 15 is closing tomorrow and I don't wanna send an order with the wrong part in it.
Batch 15 is closing now...
- daemon667 for rear grooved & dimpled early R32 GTR
- SLVR32GTR for front slotted early R32 GTR
- hayden49 for full set R33 gtst slotted & EBC red pads
- carasky for R33 gtst front & rear slotted
- woolls for EBC redstuff pads --> upgrade to yellowstuff
- scooter_r33 for R33 gtst full slotted set.
- Linden32 for R32 GTR front slotted
- P4t for R32 GTS4 AWD turbo full set & pads
- bangahh for R33 Gtst front slotted
- frankie60 for R32 GTR early slotted front rear
- madqrk for S14a 200SX slotted front rear
- Michael_1882 - R33 full set (to be confirmed)
- Nismo_S - RDA648S (to be confirmed)
No problems. Theo is that address you gave me your work address? Should I put a company name or just the Level & Street is fine?
Rianto - Although I've replied via PM I'll just reply via here too
If you could just address them to Theo Dinakis and the address I sent you in the PM that would be great. Our mail people here will sort it out and they'll get to me within the hour of them arriving :rofl:
Cheers,
Theo
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
