  • Replies 490
Posted Images
Group Buy 24 order received...
- Slyne for R33 slotted rotors & pads (waiting for payment to clear)
- matteh33 for R33 front slotted rotors (payment cleared)
- falcs81 for R33 slotted rotors & pads (payment cleared)
- rinmak for R33 slotted rotors (payment cleared)
Group Buy 24 is now closed.
Will organise and submit these orders this weekend:
- Slyne for R33 slotted rotors & pads (no payment - cancelled)
Hey Mate
After rear rotors for early r32gtr (297)
Price for sloted delivered and dimpled delivered please
Also when would I expect to receive them?
Cheers,
Dave
Hi Albert,
Right now only rear 297mm R34 GTT rotors available, as this is interchangeable with R33 gts-t & R32 Gtst... (same part).
Front is not available yet, I've been chasing RDA on exact time when they'll be available but they still can't give me a sure answer yet.
But it's gone into production it's just probably they're still sorting out either QA/Testing/Importing/Shipping that causing the delay.
Hopefully we'll hear something by early 2008.
PMs replied...
As far as I know all R32 GTST have the same size front rotors 280mm.
The only one that is different is the R32 GTR V-Spec (93-94) which has brembo calipers and this uses 324mm rotors instead of the 296mm rotors in the 89-93 model with no brembos.
But if you want to fit the R33 GTST 296mm rotors at the front just let me know...
I'll be in for the last group buy this year.
I'm undecided on which rotors to go for though, can you pm me the delivered prices for both the slotted and the dimpled/slotted.
Front and rear for R33 Gtst.
Also, include the prices for Green and Red pads all round.
Cheers!
Group Buy 25 orders received:
- WORK32GTR for rear R32 GTR rotors
- CHUNDA for front R32 Gtst rotor
tuitahi, will send you a quote ASAP.
I will... just need a good break over christmas & new year...
No worries Rianto, it'll take my wallet until March to make a full recovery from the flogging it will get over the next couple of weeks ;)
- CHUNDA for front R32 Gtst rotors
- TURISMO for front R32 Gtst rotors
Group Buy closing by end of this week! Next one won't be till in 2008 so dont miss out!
PM received, updated Group Buy 25 orders received:
- bilbo117 for R33 gtst rotors & EBC greenpads
- intouch for R32 gtst rotors (TBC)
hey mate
Need a quote for front and rear rotors for R32 GTS-T coupe 90 model, wanting price for the slotted and none slotted, and do they come with pads give me quote with pads also.
thanks Bruno
PS send a Pm quick befor due date last order for this year
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
