i noticed when i put my boost controller in and setup the gain it spooled faster than when i was just using the wastegate
i don't NEED to run a boost controller if i don't want to...if you say the hks actuators are second to none then they will hold whatever boost level they're meant to hold properly...
Gee...thanks for the technical lesson...i'm a certified mechanic and mechanical engineer and been involved with turbo cars for 4 years...as if i didn't know that a bigger turbo would cause more lag...when i said positive boost at 3500 (NOT 1000rpm) i meant that the boost gauge would read 0.0bar at 3500 or more...now that i know for a fact is abit late...i'm asking for opinions and suggestions here...i don't need to know that i need a boost controller and i need a dyno tune...so before you try to teach me how about you read your own crap first...i don't NEED to run a boost controller if i don't want to...if you say the hks actuators are second to none then they will hold whatever boost level they're meant to hold properly...
So sorry Mr education....
Best you don't assume nobody else here has mechanical experience. How well do you know me????
4 years is such a long time now isn't it?????
Tread carefully my friend...
Go ahead and improve on a HKS internal wastegate, I would love too see that.
Maybe the wastegate is not operating correctly but that is not a design fault..
Since when have i ever said i wanted to improve on the wastegate anyway...4 years also ain't that long...but its definitely enough time to know that a larger turbo will have more lag...and its definitely enough to know i need to get it tuned for it to run properly and safely...anyway...so if you do have more experience...give me a list of possible causes and i'll take them into account...instead of telling me redundant crap like how i MUST run a boost controller...
Edited by limpus
That was my first guess but after trying 2 RB20 and 1 RB25 actuator i thought otherwise. New hose with hose clamps were used so it did'nt leak.
Im going to open up the waste gate a bit more once i take the turbo out for the new motor. Theres more than enough meat in the housing to grind yet still keep the HKS popper flap and keep a seal. It cant do any worse can it.
Thats a good idea...i might have to do the same thing if i can't sort this problem out...can i ask what dump pipe are you using? is it a hks original or some other dump...cheers...
Come on now and get serious, I cannot believe some of the rubbish that is posted..
Their all questions... everyone learns from somewhere
oh p.s. getting a turbo to spool under 1000rpm? please read hpi with bee r's s15 on the front cover :) (supercharged sr20det + tdo6) :sorcerer:
I started with a blended 3inch dump. I now have another dump converted to screamer with a 2inch screamer. Still the same.
If you guys are paranoid about the actuators... best way to checking if it opens correctly and what psi its set at by using an air compressor with a guage on it... that'll determine if its screwed or not...
2nd thing is porting the wastegate hole on the exh housing... better to get it done professionally just incase you go too much then your screwed.. only your dump pipe will cause this issue if the flapper dusn't open all the way cos its hitting it..
let us know how you go
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
