Nope, its the first one he's seen to do it. I have used this dyno since day 1 when my car was completely stock it dyno'd at 97kw@wheels and the boost did the exact opposite it jumped at that same point. We then put an exhaust on and dyno'd it again, same results with the boost but power jumped to 115kw@wheels. I then had the ebc and fmic installed and we dyno'd it again and got the opposite, boost was now dropping at the same point instead of holding firm and power went up to 235hp@wheels. So I got the dump+front pipe done and power went up to 245hp@wheels but still having the boost issue.
Yes they do, I'm running very very rich at the top end, which is due to the stock ecu. I will be putting in an aftermarket ecu to sort that out, but that may fix the boost problem, looks like a boost cut. Dunno if I will bother replacing the actuator with a HKS as I'll probably be changing the turbo.
My bet is that the dyno operator T'd his boost gauge into the wastegate line. So when either the factory boost solenoid opens up, the pressure in the WASTEGATE line drops closing the wastegate slightly, increasing boost at the MANIFOLD.
A 3psi drop would have shown up as a big change in the power curve :P
The drop is to sudden and then it holds the boost to flat (approx 1psi) to be a wastegate spring I would think.
I would be checking out the EBC.
Seems almost like you still have the standard boost solanoid plugged in but some how backwards.?!?!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
