Hey guys I am chasing some parts for my R32, I hope some of you guys can help me out.
Car: 92 R32 GTS-T Coupe
Parts Needed:
Drivers side air vent (the small circle on located on top of the dash. Mark maybe able to help me out.)
UPDATED 22nd August
Edited by Triptych
come on guys some of you must have some spare parts laying around.
This guy in W.A has a stack of stuff that maybe some interest
http://www.skylinesaustralia.com/forums/in...howtopic=148692
I know it's W.A but heres the link anyways
Ryan I just want to thank you for all your help you have given me so far. Everybody I have come in contact with so far in this communty has been really nice and helpful. Thank you all and hopefully it won't be too long before I get this car looking as good inside as it is outside.
I will do spook. I am starting to think of trying my luck with Nissan or maybe Clark Rubber. Might also be time to start ringing the local Import Wreckers to.
well i am pretty sure the pump is fine, I am thinking it is the sensor that is the problem with my fuel guage not reading right so I am going to try swap over the sensor to see if that fixes it. PM me a price your looking at for the sensor. I will be checking out my fuel system tomorrow when I do my coolant and oil change.
Also my holidays from work start on tuesday so that should give me some time to give this car a good look over and start fixing things. One really annoying thing is my Door open light stays on. I have tried replacing the sender in the doors (both sides) and it still does it so I am guess a wire has been disconnected somewhere along the line.
Edited by Triptych
  • 4 months later...
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
