I have now been tuning ECU’s for about 2 years and have had excellent results. I have tuned everything from completely stock cars to highly modified with larger injectors, turbos, AFM and even methanol injection. I have currently have the equipment to tune R32, Cefiro, Silvia, 180SX, Laurel, 300ZX and a few others. I can not tune R33 skylines due to the chip used.
I have all the equipment and have the ability to do map tracing and socketing ecu’s. All you have to do is pay for the dyno time and a bit to cover my costs.
You would have to allow for 2 hours dyno time and $50 for my efforts and cost of chips, sockets, travel, and time. Normally people would charge a minimum of $350 for this service.
You will get a new fuel and timing map to suit your mods, speed limiter and rev limit set to whatever you want, mass AFM sensing will be removed so no more “boost cut” and all will be checked on the dyno. You will have better power delivery and in most cases improved economy and heaps more power.
What I will want in return is a before and after printout of the dyno runs to show the performance gain achieved. Mainly so I can have some testimony from customers. That’s all I ask
Below is a couple of graphs of cars tuned by me.
R32 skyline RB20DET Slide hiflow, Stock injectors, RB20AFM, GTR fuel pump 14psi.
R32 skyline RB20DET Slide hiflow, GTR injectors, RB20AFM, GTR pump 18psi.
If you are interested please PM me.
Thanks!
I am unable to do R33's due to the type of ROM they use. the chips are $100 each and you can only write to them once :0 so each retune needs a new chip. and I don't have a suitable programmer :)
With R32 skylines and other nissan ECU's they used an EPROM that can be erased and reused.
Cheers!
Hey Nic,
I will most likely be interested in this after I get my GTR changed to Canberra Rego, had abit of delay the last couple of weekends due to the rain. I think my car was running pretty rich hence the dirty bumper that you usually see when I drive the R32 to work.
Michael
hey mate can you remap s14 series 2 ? Also have much roughly when every thing is done ?
Hi Cambo. Yes it can be done but it gets expensive very quickly
With The S14 there are 2 different types of ECU. 1 can be tuned and the other not. You need to fit a daughter board with 2 eproms. the daughter board is $100 eproms a few $$$ and than tuning. all up including dyno time you would be looking at between$600 and that is if your ECU is the tunable one :ninja: if not you would have to hunt around for the correct ECU and would probably pay $200 for one. by that stage you are into Power FC territory.
Hey Nic,
Michael
really? i'd just come to accept this was the price i paid for buying a white gtr. i may be interested in that case. so i'm assuming you can still work some magic with a completely stock 32gtr?
a completly stock GTR will benifit the most from a remap :) they run ultra rich from factory 10:1 at full throttle and also have a slightyl erratic timing map.
you can gain 30rwkw with just a remap and no other changes :D you will also have better fuel economy and less black crap!
My car is the one in the 2nd pick making 238rwkw (now a bit more) and i never get any buildup on my bumper. (it is black already) but if you wipe it no soot comes off:)
count me in then. just gimme a couple weeks for some funds to come in.
edit - having never chucked a car on a dyno before how much would i be looking at for dyno use and would there be an ideal dyno in canberra to use? cuz obviously i'd rather use an accurate one!
Edited by shredder667
well it looks like my turbo has finaly bit the dust. so im looking at getting it high flowed within the next 4-5 weeks. once thats done i'll finaly get you to tune mine.
no probs ;) happy to help.
checkout sliding performance turbos :D thats what have put on mine and 240rwkw later i am really happy with it. they cost around $1000 vs $2000 for a GCG hiflow
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
