i cant wait for future music! i cant believe it is this weekend already!!!
I went to Zeta bar at the hilton on sat night, that was an interesting experience, lots of fake boobs, massive lips, 30yo women trying to look early 20s, lots of people with $100 notes, was a nice place, music was very ordinary, drinks very expensive, only got in because i had 2 chicks with me...... nice view of the qvb, and a woman in the bathroom giving you paper towels and offering you some nice cologne haha....
dont know if ill be going back in a hurry
MMMIIIILLLFFSSSSSSS with 100 dollar bills!!! me and mate visting this place fooo sureee
  • Replies 105
just o be on topic, there is a Nice Salso club behind Cargo, on that street in between cargo and bungalow. La Vica or something, something different, but a small cllub
wtf is SALSO? :)
And the place is LA CITA.
yeah why do you ask?
Well if she thinks that the car scene is better than sex... :D
Very small.. trendy place. On a good night you get some of the older beautiful people crowd.. nice joint
my work mates always tell me to come with them as they say its really *special* and hard to get in but they know owners blah blah but i'm never dressed for it so I havent gone there yet lol... wat u mean by beautiful older crowd ?
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
