Hi Boyz and Girlz
Just looking 4 somewhere good in sydney 2 tune my power fc computer on a dyno.
Any1 had 1st hand experience with anyone good or know somewhere that is very good with them?
ThanX
Jamie
:Pimp:
https://www.sau.com.au/forums/topic/15964-power-fc-tuners-in-syd/
Try Ric Shaw Performance. Dad (Bonkers) has had very good things to say about Ric. See this thread for more details
I will be taking my car there as soon as I get an issue sorted with it.
If you live at noosa though how come your getting car tuned in sydney?
Dan.
my car is down there now alllready and it is hard tryin to find some1 reputable up here.
I am pretty sure i am gonna get croydon racing development to tune it. they have years of experience with tha power fc
Let us know how it goes with the pinging and such after CRD tune it :D
Guest SXU29T
hope u bring ur check book though! my friend supposably was getting his car tuned their for $140... but his car wasn't boostin properly and they had to use a few cable ties to secure the vacum lines (his gts-t s2 got 156rwkw @ 12psi with dumpy back exu & filter is that normal?)....well any way 40mins later when he had to pay they said that'll be $375!!!!.....a bit david jones for mine maybe they jus saw us comin?or may be thats why they changed their names from " croydon autowroughts"... to croydon racing developments.
There are lots of recommendations for tuning and other work - but let's just say I'd never go to any place that change their pricing (much) from their original quote... esp. not $140 -> $375.
Put it this way, I paid $1,000 (for example) to change a turbo and things went up shit creek but it still ended up costing me $1,000 even though I wasted a lot of peoples' time and patience.
T.
I got told on avg it tends to be $600 for a full days work. They empty the fuel tank and fill it with fresh fuel. THey then check all the hoses for vaccuum and ic pipes check plugs and make sure right heat range gaps etcc and just generally go over the mechanicals 2 check evrythin b4 they even start it on the dyno. Then when tuning they don't just change af ratio they can change just about every parameter the power fc offers with the laptop software they use, rather than just stuffin round wit a commander =P
I don't mind paying for quality work
I will let u know how it goes
:Pimp:
Jamie
You're kidding yourself if you think there are lots of tuners who have the Apex'i software.
Datalogit? Maybe... but not the full on Apex'i licensed software.
I'm not willing to do a full on dyno tune until I'm COMPLETELY finished with all engine mods.
And at this junture I need close onto $3,000 to finish everything off, so hopefully not too far now :(
T.
The power fc commander is exactly that... a commander... you can change evey parameter in the computer that is required for tuning the car that it is designed for, which I believe is some 800+ parameters.
Croydon is not my choice as for the money they charge I can get my car tuned twice at Ric Shaws, and I have heard and seen similar results from both.
that power figure seems low, but then, the dyno settings may have been set to abnormal conditions, or maybe it has a monster torque curve instead :(
ed,
Your power out put is proportional to the amount of boost you run mostly. If it has a power fc the it will manage the engine a bit better and can be programmed to give more fuel change timing etc to gain a little more power. If it had a power fc then probably a mark of 175-190rwkw depending on condition of other engine parts and connections etc.
  • 7 years later...
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
