Jus wondering what you guys think of these lights....
Not the greatest fan of them on a black car, but They are to go on a silver 33
just after some opinions......
also i cant find the link to where someone was selling white faced gauges and the bezel part around them, can somone plz link me!! cheers
https://www.sau.com.au/forums/topic/159744-led-lights-for-r33/
They are awesome pkblade... this reminds me of the time i had a lancer. and I had to take the choice between ralliart altezzas or cheap piece of shit ebay ones. I chose the ralliart ones and they didnt have problems that 90 percent of the ebay ones had with failing parts needing replacement and broken mounting rings and screws from normal driving.
Does Nismo make an Altezza-style light for any skyline?
yer i like them to... im jus trying to do or find something different! skylines have been done to death lol but i still dont want people to look at it and think WOW thats ugly lol
actually cubes dude, the ralliart altezzas didnt look rice on my 4 door lancer, they gave it a bit of a nice edge to the rear. defintely worth the 100 dollars i picked them up for.
EDIT: The 8 inch cannon on the end of the upgraded headers, hiflow, cat back exhaust though did... ;)
Edited by Pauly33GTS-t
hes a homeboy.
"wak" is bad as in no good.
a sentence would go something like this..
" yo man themz tail izzlez aint the shizzle ya dizzle? Themz wak."
then you have to do the bolt before he pops a cap in yo ass.. LOL
hes a homeboy.
Damn straight caucasion..........
Why would one want to F#%K around with the best tail lights in the world :)
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
