Hey peeps,
As the title says i need to borrow a set of 33 stockies for a mate to get thru Regency, Think we have 2 at our joint but am need ing another 2 possibly a full set! With tyre also would be good, NO skids or anything will be done, just a drive to regency and back!
AND of course there will be some liquid refreshments as payment.....
Any help MUCH appreaciated!
Darren :D
https://www.sau.com.au/forums/topic/159778-help-needed/
I have a full set of R32 and R33 stockies darren.
I have them staggered on my car. 32 front and 33 rear.
You can borrow them if u want. Only prob is that one of the 33 stockies loses air. Dont no why. Its the one that hit the enbankment. But did not split or blow up.
Get back to me if ya want mate.
Brenton
https://www.sau.com.au/forums/topic/159778-help-needed/#findComment-2968179
Brenton
So you have 33 and 32 stockies Brenton?? Does that mean you'll be able to run around with 32 stockies for a while??
https://www.sau.com.au/forums/topic/159778-help-needed/#findComment-2968409
Darren give me a ring - my brother-in-law has a full set of R33 stockies with good tyres just sitting around gathering dust in his garage. He is looking to sell them, but I am sure he would lend them out.
https://www.sau.com.au/forums/topic/159778-help-needed/#findComment-2968779
Yeh I can run around on the 32 stockies for a little bit.
As I said. 1 of the 33 stockies has a small air leak. So instead of giving me drinkies u could just fix it. I assume u will just need them for the day to regency and back right?????????????
PM me if ya want.
https://www.sau.com.au/forums/topic/159778-help-needed/#findComment-2971689
Yeh sweet as Andrew sounds like a plan, Not entirly sure how long he needs them for but i will make sure it's just for the peroid when heading to Regency! will see ehat he wants to do about it and go from there, Will call you about them just before he needs them!
PM me if ya want.
I'll see how we go Brenton, might be easyier to borrow Andrews Bro in laws as they aren't on a car or anything! Will keep ya posted, cheers!
https://www.sau.com.au/forums/topic/159778-help-needed/#findComment-2973521
if worse comes to worse deluxe, come to my place not far from sinistas (closer to holden hill) and u can switch over ur rims onto my car for the time being, my cars not moving from X location because drivers side window is buggered and I've got auto electrician coming to my house within the next 2 weeks.
https://www.sau.com.au/forums/topic/159778-help-needed/#findComment-2973662
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
