  • Replies 150
Im out....a CAB just ran up my ass about 30mins ago in st Kilda :):):(
it dosnt look to bad from what i could see.... couple scratches on rear bar and its pushed in a little,
but exhaust was pushed forward and muffler has about 30mm clearence from the ground.
ill take to my tune shop on mon and see what the verdict is....i might even have it fixed in time to go on the cruise i hope.
Anyways if im not there you know it was alot worse than i first thought.
I'll also post some pics if i get some time.
Edited by Borgs
sweet more ppl coming, just a reminder to those who havent already realised it, Apr 7th is EASTER SATURDAY, if u working i feel sorry for you, if u arent, come on down and join in the fun!
definatly cant make it...have to work.
Have fun though everyone an be safe, there will be HEAPS of traffic on the GOR on easter saturday. Be patient (you'll get stuck behind plenty of caravans & slow cars) & remember....we all have turbo's & good handling cars, dont be a dick trying to prove your "hero" status
cheers
hey guys
back from the air show (and lost myvoice :happy: )
any way ive up dates the list, and sad to see a few of you un able to make it.
any way its still a go and ill see you guys there on the 7th
hey guys
getting closer!!! only 10days to go!!!
for those who havent yet decided or have work that they are unsure if they can get off, plz let redlineingr31 know so we can get a definite number of cars that are coming. we dont wanna leave the servo til every1 is there.
wouldnt feel too good if some1 was left behind. so for those of you still deciding, plz dont forget to let him know.
cheers
see you there
daniel
yep 10 days to do.
just a reminder for any body thats undecided can you let me know know later then 48 hours from the cruize i.e april5 as if your comeing or not this way we dont have to wait for any body that ant turning up.
lets see now. check list
cruize map, typed and decived on. done
brakes to be blead.
have money for fuel :(
keep counting down till cruize
also if any body who is comeing who can bring SAU merchandice or sticker would be grate. plz let me know if you plan to bring these items.
chears brentt
I can't believe your coming down here on Easter Saturday!!!
I'm working in Lorne at the moment, and all the caravan parks and motels etc are fully booked. It is their busiest time of the year believe it or not.
Anyhoo, wish you all safe travel and be patient :(
I hate this...said I could now I may not .
Looking for Shims(21) :D for cams and Z32 air intake for adapters or new kit.
Why me?
cnt you buy the shims and go to a wreckers for a z32 air intake adapter. or ring up zhope they specerlise in z cars i.e z32 z33 350z they might have your what your after dont have there no sorry but they are in vic
Hi all, new member here. I'd like to come along... I don't own a line (yet) but been reading heaps on this board over the last few weeks (lots of good info!) and probably look to import a R32 GT-R in a few months.
This should be a great chance to talk to people and have an up close look at people's rides.
Hope to see ya there!
dilmah
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
