Hi y'all
My tuner reckons he needs my car overnight so he can set up the "cold cranking ???" on the PFC first thing in the morning when its stone cold and only a tiny window to do it in according to him.
Found out he was using a dyno somewhere else but didn,t tell me his one was not working
He clocked up 300k in my car and has set boost @8psi (9psi standard) because he wants it back to finish it.
Not f'kn likely once bitten twice shy.
:) He had the car for three days before I demanded it back
Very sloppy pfc + boost kit install ie vac line draped across hot plenum and Map sensor at a 45 degree angle to the vertical Book warns you it must be vertical or overboost may occur. Easily fixed though.
Its a really nice car I think he was using it as his daily driver A low act
Anyway water under the bridge.
Could someone tell me what the cold cranking set up is
I can easily wind back up the boost with the hand controller and monitor knock levels Map traces etc.
Have been getting right into this tuning lark thanks to all the excellent info in the threads just the theory so far until I get my head around it all . before I do it for real.
So is this guy taking me for a ride or is what
He comes highly recommended from my research for a good tuner on this web site. Ha
Would like some input please
Cheers
Mike
No Names
https://www.sau.com.au/forums/topic/159798-pfc-cold-cranking-setup-help/
  • 1 year later...
tell him NOT to touch the standard PFC settings for cold start and that you dont want a cold start tune.
IF your engine runs like crap in the morning after the tune then il get you to post up your settings so we can double check it across the stock settings in case the guy trys to be a smart ass.
I have NEVER EVER had to change the cold start and run tuning on ANY Power FC on ANY Skyline.
Cheers
Gary
If his factory cold start on his PFC has been tampered with, I'm assuming that a reinitialize and start over again would bring all that back to standard again?
yes you could re-initialise it to reset the cold start settings but that would erase the whole tune
you can simply ask someone who has an un-modified (ie: almost everyone) cold start settings screen and change the numbers back
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
