well as it so happens, i was an AE86 drifter for many a year.
My AE86 had a Toyota Racing Development 2way LSD and about 85 kw at the tyres. The difference being that it was a live axle arrangement. My 86 was very oriented toward going sideways rather than going fast. And therefore a flick of the wrist in 2nd or 3rd gear would result in a drift being initiated. This was more to do with the pinion angle and the rose jointed rear end than the diff.
If you wish to go fast point to point, even in an NA skyline, first spend your money on some 9 or 10 inch wide rims and good tires. I firmly believe a viscous LSD from a turbo skyine will be adequate as your unlikely to overcome the ability of that diff with NA power. But if you can get that 1 way mega cheap, then get that.
from what i was reading earlier in this post, why would you want to change to a turbo vlsd diff, the diff in my na at least is a vlsd na diff, with the shorter ratio it will accellarate quicker and its still the same viscious lsd set-up.
Definitely..
Run decent tyres with VLSD and you can get away without having to run a better diff. Run crap tyres that break loose easily and it will single spin and just not hook up.
i already have a set of track rims with 255 tyres, and have some semi slicks in the pipeline as my wallet allows me.
thanks for the insight andy - looks like i'll be making some enquires into this diff.
some na skylines didn't come with an lsd - so swapping to a vlsd using their standard crown and pinion to maintain their short ratio is an upgrade.
Depends what you mean by Na diff...
An R200 is an R200 all the same strength.
The diff centers, one being the weaker N/A the other being the tough but single spinner VLSD and in the GTR's case Mechanical clutch LSD.
So either way your going to have to spend another couple hundred having a diff specialist (Boss Automotive here in SA) setup the ratio with your LSD, he also shims up the vlsd crap while your there.
I have a 4.363:1 ratio for $100. So it will be a 300-400 exercise to swap ratio's with backlash etc all setup nicely.
hey i own a 1992 r32 type m gts25 and i dont think it has a lsd but anyhow its starting to make clicking noises when taking off gently from first and also in reverse, im wondering how bad this is and if ther is a solution for it, it doesnt help that the idiot at the tire shop put 245's all round from 215-225's, i was thinking of swaping with a gtst diff but now reading this with the ratios maybe i ought to find a na lsd 1.5?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
