and how was it.. got a quote..?
i need a water pump done on the bloody liberty.. anyone that knws a place cheap.. doin Tbelt aswell.. and retension the flywheel bolts..
its a big job and i have no time to pull the engine out myself.
  • Replies 54
I am waiting for a call back from them. My car is still with them and when I try to call them I am getting their answering machine, they must be on lunch.
What was going to be approx $80 and 1 hour to be done while I wait has turned into $220ish and all day.
If the quality of the work is good then I have no problems with the extra time, I will just know better for next time.
its hard to find a workshop these days that will actually use communication skills
that's why i was amazed when i used elite racing. dan called me to give updates and called before even thinking about charging more than quoted so we could discuss my engine plans and his plans. A1 communication.
what are u getting done???
Got the car back. No unauthorised work was performed. They looked over the whole car and printed out a list of minor things that need doing.
All seems good. It was a good experience all round.
showbag,
I had to get the gearbox and atessa system drained, then have the atessa system flushed to remove the gearoil that was put in it.
So....... have you actually left the car yet??? Or are you still driving around with a big silly grin on your face???
i reckon hes got a massive cheesy grin plastered on his face, the same one as the first time he got laid.
hell i would if i was driving that gtr
You are assuming Ben has been laid. I believe he was the inspiration for the "40 yo virgin" movie. :blink:
Is it really THAT different from driving a well set up GTS-T????
If it is....... I will have to see for myself then......
i dont think it would be that different, but i just love bens gtr, its the only gtr that i truly like.
You are assuming Ben has been laid. I believe he was the inspiration for the "40 yo virgin" movie. :ermm:
Just because I was smart enough to not implant my seed and prove how bad it was doesn’t mean I haven’t spread it around on occasion! :yes:
Yeah the car is back on the road, sorting out the next bunch of go fast mods now to be fitted over the next 4 weeks.
If anyone has info on using RB20 Air Flow Meters on a GTR then please PM me.
just on the tuning side of things, charlies at wooloongabba are very good with skylines. ive never had a problem with them, and ive got a few other mates with rb's getting their cars tuned there.
:D Charlies is still there?? i thought he went outta business is shop looks really empty and have 4 sale signs up. :bunny:
hmmm, ive heard that from a couple of ppl but that was a few months ago and my car has been in there to get tuned since then and i didnt see any for sale signs nor was i told they were shutting down. thats not to say it hasnt happened. my car was in there about 4 weeks ago so something may have happened since. shame if they have shut down, dave is a great tuner.
Edited by bretto
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
