Im driving home at night, and i notice while at a set of red lights, that the headlights flicker quite frequently. my sister was following me and told me that the rear tail lights do the same. does anyone know why this is so? is it normal? if not whats the fix?
https://www.sau.com.au/forums/topic/16070-lights-flickering/
Check the voltage regulator on your alternator. Flickering lights is one symptom of a dead regulator. If it is dead, get it fixed asap. I know someone who had an old 4cyl Magna and his regulator was gone, which meant that his alternator was putting out up to 16 volts.
This may not sound like much, but within a few days (not being diagnosed) it killed his stereo and all of his gauges, one by one. And this is with an old carb'd Magna, imagine the damage that could be done to the expensive electrics of a Skyline!
The simplest way to check it yourself is to put a voltmeter across the battery terminals and rev the engine in neutral. The voltage should not go any higher than around 14.5, probably staying around 14 or even a little less. If it's more than this, take the car to an auto electrician, who will replace the regulator for around $100. It's a 5 minute job, usually they will only charge a few bucks for installation.
https://www.sau.com.au/forums/topic/16070-lights-flickering/#findComment-329390
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
