after getting my car cleaned during the week (get it done quarterly now)
and then spending today waxing and finishing the job off
ive driven to a wedding, come back to the car to find f**kING WHITE PAINT all down one side of the car and my front left and rear left wheel
covered in paint
the wheel arches are totally white (my baby is blue with sparkles) and then theres large globs of paint flicked all down the side of front and rear door
i sure as hell didnt drive through no paint puddles, so i can only imagine its fresh line markings somewhere between holland park and suncorp statium (well the church on the hill above it anyway) via the freeway
I f**kING HOPE MAIN ROADS ARE GOING TO PAY TO FIX MY f**kING PAINT JOB
i just came home from the wedding and have spent the last half hour with metho cleaning and recleaning the affected side of the car
signed
slightly upset spook
Edited by Spook's_Skyline
https://www.sau.com.au/forums/topic/160781-im-fscking-irate/
covered in paint
signed
Bugger mate thats some bad luck right there :(
Shouldn't clean it just yet..take pics first. Then get a quote for a respray and send it along to BCC for a claim see what they say. I've heard of ppl running over potholes, damaging their wheels and got compensated by the council.
this happened to me a while back.
hit a pot hole, stuffed up the right hand drivers side suspension.
brought a 2nd hand strut and that, had someone install it and then sent the invoices and bills onto BCC to reinburst me for the cost along with some photos of the pot hole.
2wks later a cheque was sent out to me.
cleaned most of the paint off (except the inner wheel arches where its coated THICK)
just took a heap of pix and will have a closer look in daylight and will examine teh damage
im hoping most of the paint has been cleaned off yesterday
Backtrack your route and see if you can find the offending section of road spooky. Take some pics and do as toy did. I cant believe they didnt have a wet paint section cordoned off.
and on the flipside, they flat out refused to fix damage to my vehicle caused by a pothole, citing legal precedents that they don't have to pay etc
real clever man, he'll get paint on his car again
Edited by geeteaess_turbo
I hit a pot hole in ipswich. It was an existing pothole which had been repaired, but the repair bitumen had slid away making another pot hole before the existing covered up one. Anyways, i buckled my 17" mag on my bluey after not seeing the hole and being unable to swerve around it at the last second. I took photos of the pothole and road and had my mag sent away to be repaired. I filled out a compensation claim form to have the $125 to be repaid to me for the cost of the mag repair. I received a letter from one of the councillors saying they refused my claim as it was the road that simply had another pot hole and not the repaired part which had done the damage.
Not too mention the bloody councillor then had the nerve to send me a christmas card a few months later...
i found the section of road with fresh line markings today (i think its marshall road, on salisbury side of the freeway)
im gonna shoot mainroads an email/letter tomorrow and see whats doing
damn, that sux... i hate the roads here they really kill your coilovers after a while!!.. and damn bumps and dips in the road.. gota drive so slow to see these things these days.... :wave:
wish i heard more good stories about being refunded be the council :pirate:
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
