Hi Guys / Girls ,
Me and my business partner sam have just moved from the uk to the sunshine coast to sell rota wheels in australia,
Hope to get into the local import scene once we have our demo car sorted and im needing an adrenalin after selling my UK demo car (EVO X RS)
So just a little post to say wave.gif hope to see you all about soon ,
Some pics of our previous cars
Hope speak to you all soon
John
and customers cars
Let me know if any of you guys are up this way and any meets / cruises
PS has anyone got a r32 gtr i just need to ask i quick question !
Hey peoples,
My name is Josh I own a yellow R-34 Skyline. Had her for about 10 months now and she is my pride and joy.
I live at Mount Gravatt just near nathan Campus. Go to sunnybank a fair bit and see alot of nice imports around.
Nice to meet you all!!!!! If you see me round don't by shy and come say hi...
Hey peoples,
nice
i've seen you around the area
i'll give ya a wave if i ever get the chance
Hey peoples, Ive just moved to the Gold Coast and I'm in the market for a 33 GTST. Will be buying in a few weeks as I have my eye on a few. Just a small upgrade from the MR2 hehehe. Hope to see some of you around.
Cheers, Mark
As if we race on this forum! only at the trackz yo!
welcome all noobies!! make sure you come to this thursdays meet! at Baskin and robins at indooroopilly ay 7.30 or kenmore nandos ay 6.30
it's just a few of R32 and other sports cars drivers I've met on the road were kinda aggressive lol
Edited by NY-NA-34
btw I can't pm you back it says I'm not allowed to yet
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
