Think the JUN Z was doing 360 in the opion vid. Alsome car 1 million pounds well spent.
thought one of JUN's supra recorded some like 401km/h back in 2001.
dont think the carrera GT would had the chance against the veyron on a straight.
that vid against the r1 isn't that good. they aren't into it long enough, and the bike is only accelerating after the car has. really need a proper comparison. the car and the bike next to each other and then accelerating at a certain point.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
