Hi i own a R33 gtst and am trying to locate a power fc to suit but am finding it extremely difficult to find one as they are a discontinued line. Now my question is are there any other ecu options out that are comparable to a power fc ? If so what are they?
Many thanks
Peter
https://www.sau.com.au/forums/topic/161069-alternative-to-power-fc/
From hot 4's info (I was going interstate and had to buy something to read .. Dont flame me :D) Wolf seems to be the best features for $$$ dont hold that one to me .. But they said it was a touch better than a power fc .. Big call I know .. but i read it ..
Just read that the wolf is $2200 with hand controller .. Thats a motza!
Edited by DECIM8
Many thanks
Peter
hope you find your PFC they are good ecu..
i found a second hand pfc not long ago for $1300 but i did some calculations and it wasnt worth it. If i got the pfc i would of also had to buy a z32 afm & splitfire coil packs. For that much money i can buy a microtech L12 with bosch coil packs, remote screen & wiring loom. Advantage to the microtech that its brand new & its also less than rrp. The pfc was more than rrp.
I knew a guy with a wolf system. He may of just been unlucky but he said it was the biggest piece of shit ever.
Edited by r_speedfreak_r
There is already an "alternatives" thread.
See link below, there is 6 pages or so to give you a great idea.
http://www.skylinesaustralia.com/forums/in...;hl=alternative
Im locking this as its already been covered a few times.
Cheers
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
