  • Replies 88
Posted Images
thx.engine mod wise, that I know of fmic, oil cooler, oil filter relocator kit, earthing kit, cams, z32 afm, rb25 hi flowed turbo. Last dyno put out 172 awkws with a t piece in it no boost controller, not real happy with that figure. Need to get it dynoed again and sorted, now I have a boost controller In. Want to have it sorted properly.
  • 4 weeks later...
Well have the car back. Match is not 100%, looks good from some viewpoints, but not as good in others. Spraypainter hates my car, the color is very hard to match, may be taking it back in a week or so to finetune it, as place I took it to said they'd be playing around a bit with some different color cards. Either way I think I'm gonna start saving for a full respray perhaps, as the rest of the paint isn't in the best shape anyway, will probably need to get a new lip for it to as the one that came with it isn't too great, need to see if I can finetune the front bar fitment too.
thx, I still blame you and your pics lol, gtr bar does set the car off nicely. Still need to fine tune fitment of the bar as well.
Well took some pics this arvo after going to the hardware store for some screws etc to mount my number plate (slim line is on my list of things to buy)
Tooks some more pics, with the lip now on. Color match looks good in some angles and shit in others, it is a bastard that way lol
does feel a bit ridiculous how low the front lip is, lol. Still troubleshooting my headlight clips, and now debating whether to put the gtr grill on or not.
If you can, defantly put the grill in. I dont know why but a set of work XD9's in black would look motherf**kingPORN. See if you can get a photoshop?
XD9's with a lil bit more slamage and gtr grill..... :(:spank: nuff said
Thx I'm working on the gtr grill :P , just my headlights are driving me up the wall, had a look at the xd9's and the colour reminds me too much of my old rims lol. That and the fact I'm on my 3rd set of rims, doesn't make me want to get some new ones atm lol. Will probably keep it at the same height too, as it was bottoming out before I had it raised an inch.
Next on the list is to get the car re dynoed, and them maybe some other light mechanical mods. After that respray probably, idk. way down the line.
Probably getting the front bar resprayed again as well, just not sure atm.
  • 3 weeks later...
Hey Chris,
What bonnet pins did you use?
Could I get a closer pic of them?
my GTR bonnet has holes for the generic type of bonnet pin.. I bought an aerocatch bonnet pin but didnt like the look.
Cheers mate
Edited by GTS4WD
  • 5 weeks later...
Yeah looks good from further away lol :cheers: . Sort of decided now to spend a bit more money on finetuning the performance, but apart from that leaving it alone as much as possible, and getting some more motorsport events done.
In the long run If I still have the car in a few years, which I'm planning to, It'll get a full respray, car will need some work to fix all the panel gap issues. Don't really know anyone in the industry to save me money
Looks like my car had a bit of a hard life in japan, even though it drives straight, the panel gaps are shit.
  • 3 weeks later...
well f**k me, found the japanese for sale add for my car, cars changed a bit, but I now know where my catch can went
http://yamayagroup.co.jp/5606hnr32.htm and my km reading wasn't set at 152000 km when i got it, still a while off on my revised odometer... :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
