Na, doesn't damage it too much (it will do damage if you just leaving it sitting on the limiter for ages). It happens because the rev limiter works by cutting fuel, which causes the afr's to momentarily lean out. The PFC reading only measures the maximum knock, average knock would be a much more useful reading here.
https://www.sau.com.au/forums/topic/161250--/#findComment-2994117
average knock is 10- 15, never goes above that no matter how hard i drive, this is the 1st time its been this high and i didn't sit on the limiter, only hit it and engine light flashed, got me all paranoid. but when i revvied to just before rev limiter a few times after knock was 10 - 15 the whole way to 7000rpm, i set rev limiter at 7200, so its never revved too hard. thing is i've hit rev limiter before and its never got that much knock before, thats why i got worried
Edited by scarface
https://www.sau.com.au/forums/topic/161250--/#findComment-2994145
Even if the car did have a big detionation, its still running fine so i wouldn't be worried about it.
I had knock of 152 once... i think i got a stone in the engine bay hahahah
You only need to worry if knock is going above 40+ like everytime you drive, then you'd need the tune looked at, under 15 is very safe, tuned fairly softly :wave:
https://www.sau.com.au/forums/topic/161250--/#findComment-2994247
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
