Hi all.
Looks like my coils have shit themselves and im looking at buying some splitfires.
My current set up is a microtech Ltx-12 and a MSD 4 ignition with a Ford coil pack on a series 2 RB 25DET.
Yes i know its Ford, but they are going.
Do i just order the series 2 split fires or something different with the set up i have.
Oh and what is the expected price to pay, ive been told around $600 mark.
Cheers.
Edited by subzeroR33
https://www.sau.com.au/forums/topic/161358-split-fires-and-msd-4-ignition/
the split fires are direct replacement for the std coils...
soo S2 run the ignitor in the coil pack itself .. is this how your ford ones run? i wouldnt think so with the MSD 4
here are pretty much teh cheapest in Aus you can get the splitfires for that i know
http://www.skylinesaustralia.com/forums/in...howtopic=153971
Yeah im not sure if i can run the split fires with the set up i have, maybe someone knows.
Thanks for the link Craved.
From memory, the Microtech LT12 has the ignitors (6 of them) built in and so on a 6 cylinder it can run full sequential ignition.
The term "MSD4" is bit generic, you will need to be more specific. For example, if it is a MSD DIS-4 HO then the Microtech ignitors are being used to fire in wasted spark mode, so you should have one ignition circuit in the MSD not being used. Check that with your mechanic and/or tuner. Personally I would have run 1 x MSD DIS-4 HO and 1 x MSD DIS-2 HO so that I could run full sequential ignition.
Regardless, if the above is in fact the case, then you need R32GTR/GTST style Splitfires, ones that don’t have built in ignitors. Keep in mind that even with 6 Splitfire coils, you will still have to run wasted spark, as you only have 4 (3 used & 1 not used) ignition circuits in the single MSD DIS-4 HO.
:) cheers :D
:) cheers :D
;) cheers :O
It is a MSD DIS 4. Yes the microtech does have the inbuilt ignitors.
Thats what i was wondering what type to get with or without inbuilt ignitors.
Thanks for ur help mate.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
