so i managed to limp my car up to andy's to get a new radiator installed. As is always the case with these things, nothing went quite to plan :)
Firstly, in the r33's, does anyone know what the temp sensor that goes into the bottom of the rad is for.. well obviously its measuring temp, but it doesnt seem to controll anything as the guage temp sensor is in the engine...... Atm we've left it disconnected but i wouldnt mind knowing what its supposed to be doing. Perhaps it controlls the secondary fan ?
When installing the radiator, we ran into a problem.. the mounts at the top of the radiator didn't line up properly..... solution ? ZIP TIES !!
anyway, will obviously try and sort out some new mounts in the next week or so. Shouldn't take more than a few minutes with a drill.
Will let you all go how my new tune goes tomorrow.
big thanks to bunta for the huge help he gave putting this in.. legend !
https://www.sau.com.au/forums/topic/161513-my-new-radiator/
What type of radiator did you purchase?
One of those generic chineese ones that Just Jap sells
It didnt fit my R32 properly nor did it fit the R33 properly so who knows what it is for! But it works and mostly fits so for a sixth of what you pay for a big name one I reckon it is still alright!
https://www.sau.com.au/forums/topic/161513-my-new-radiator/#findComment-3000233
Handy to know, If you dont mind me asking how much did it cost?
https://www.sau.com.au/forums/topic/161513-my-new-radiator/#findComment-3000631
so i managed to limp my car up to andy's to get a new radiator installed. As is always the case with these things, nothing went quite to plan :kiss:
If it has a butterfly nut on it that's the drain plug on the bottom, and the top mounts just flip upside down and reverse the rubber rings, drill 2 holes in closer to the middle if you need it :sorcerer:
https://www.sau.com.au/forums/topic/161513-my-new-radiator/#findComment-3001752
I replaced my radiator for my old 33 it was a direct fit, isnt the plug at the bottom a coolant temp sensor?
https://www.sau.com.au/forums/topic/161513-my-new-radiator/#findComment-3001840
:kiss: thats what I suggested to him!
I just found out that the little sensor in the stock radiator is for the fan apparently it only operates when really extreme temps are reached..the temp sensor for the guage ect are on the engine
https://www.sau.com.au/forums/topic/161513-my-new-radiator/#findComment-3001987
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
