Ha, I'm going to get those tuff clamps from just jap to enclose that massive 1.25 bar of BOOOOOOst psi!!!
It gave me the s$%ts.
Yeah, run quicker than 12sec now and you need andra license $120, I'm sure.
lol
the nanny state mentality has extended to WSID- 'snot like an 11.whatever second car is all that hard to pilot in a straight line on dead flat road, especially an AWD one :laugh:
lol
The super street license is an ANDRA regulation - it's got nothing to do with WSID and the same rules apply at any ANDRA compliant drag strip in the country :)
Sorry for my ignorance of the situation
But it still begs the question- Has there been some sort of proliferation of incidents involving 11 second cars?
(answer = no)
Seems like a way to generate revenue to me.
(answer = no)
From what I have been told, when you hold the Andra licence there are certain regulations on top of what others have, that you then must abide by also, or you cannot run at the track again.
The extra regulations are all involved with safety aspects in the car etc.
And yes, there have been incidents over the years where people have lost control of cars, whether they be the high end dragsters/funny cars, or road cars, there have been accidents in all, and the severity seems to increase dramatically once you pass under around a 12.5second 1/4 mile.
:) hello guys i own the black one, i ran 11.86 then 11.87 and got told anything from 11.99 down you have to get the licence and was told to get the licence or don't line up again, $ 120 for one more run, not worth it
i'll have to head out again, and use the tripod this time.
Edited by Angus Smart
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
