Howdy people,
Posting up for a mate.......he can get his hands on some 20 Injectors cheap which are side feed like RB25's and we are wondering if anyone has done this mod before....success / what needs to be done etc....
The standard 20B injectors are 550cc, thats all i know im unsure if they will fit in rail etc?
Any info would be handy. :rofl:
- Luke
https://www.sau.com.au/forums/topic/162358-rx7-20b-injectors-for-rb25det/
Howdy people,
Any info would be handy. :happy:
- Luke
From memory (it's been a while since I had a set) the 20B injectors are the same as 1JZ & 2JZ, so they need adaptor rings, same as aftermarket SARD injectors. You can buy them separately anyway, so if the 20B injectorrs are cheap enough, grab them. Be careful though, I think they have 3 injectors at around 370 cc's and 3 at 550 cc's. Not all six flow the same.
:P cheers :huh:
As sk said, they are pretty much the same as sards.
You need the collars, and some standard denso type plugs and shave a bit off some of the plastic down at the bottom of the injector.
They work in mine.
  • 2 years later...
:P cheers :(
Anyone know exactly what collars are needed to fit the 13B side feed into the 25 rail?
Does it have to be sard or are there any other options?
Also i see sard has two different sized collars... one for the the 550 and one for the 850.
Thanks.
If you do a search you'll find lots of info on RX7 Turbo injectors .
From what I read it gets a bit confusing because the colour and even part numbers can be similar /same , it seems to depend on the model year of the donor engine .
I think the only hard and fast rule - with the conventional looking rectangular connector type , is that the locating tag on top of the fitting is offset to the right with high impedance injectors and center with low impedance peak and hold type injectors .
People say you simply file that tag off the high impedance injector and fit readily available std rectangular plugs .
Cheers A .
Ok guys after doing some research it seems like the Subaru STI side feed yellow top injectors can work on the 25det
Alot of Sr20 guys are doing the swap and says it fits as oem in the rail, are high imp,and just the connectors are different.
The problem is a little confusion over the USDM which claims their own is 550cc or thereabouts and the JDM spec which is 440cc
If this is true i can't believe there is no info on SAU to support this...... yes i've searched!!!
Anyone have any further info on this????
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
