Hi guys, not sure where to post this so sorry if in wrong place. where the best place to get a engineer certificate??? and ruffy how much?
im in sydney
go to rta website, type in engineers - gives u a list of engineering signiatories. took mine to mobility engineering in hornsby. how much depends on what u want engineered. most places charge $500 and up. the main thing they want to see is that it passes noise and emission test - exhaust below 90db, needs to be tested by EPA, in botany. i had a 5 inch tacho installed on passenger side dash which had to be removed for safety reasons. basically the car needs to be safe and pass adr legislation
hope that helps
https://www.sau.com.au/forums/topic/162446-damn-cops/#findComment-3017946
Thats a pain in the ass. Does anyone know what legal mods you can do to ur line, if any?
This is for Vic, each state will have their own legislation though. Try the web, search EPA websites. Also you can look at the dotars website for ADR's etc.
EPA_Guidelines.pdf
https://www.sau.com.au/forums/topic/162446-damn-cops/#findComment-3031395
shit, n i thought we had it bad in perth with all the antyhoon laws that they take the car away just for a little burn out or "slip".
lots of times if u take the car to a diffrent pit with more felixi engineers n talk to them nicly they will not ask for engneer papers for smal mods like u mentioned anyways.. well thats the case in perth. the only two times we had to get one of them was with a fully rebult n turboed honda type R and a gtir/SSS convergen .. but that is cuz usualy when we take the car to the pits here we make sure we take off all extra little things n boost them down a little, put a silencer in them and take the blow off out.. if the work on the car dont look home made n there is nothing moving, leacking or sounding too bad then they are usualy ok with it provided u get a nice person.. it might be worth ur time trying in a cuple of diffrent places b4 u look for engineering cert with small mods like that..
good luck
https://www.sau.com.au/forums/topic/162446-damn-cops/#findComment-3034530
thanks heaps guys!!!!! got hassled by cops for HKS SSQ BOV.... and intercooler.... and apexi filter......and exhaust.... blah blah blah!!!! $128 warning!!!!! he said fix them. in my mind... GET f**kED! i lov my car!!!! hehehehehhehe
BOV and filter are illegal, exhaust will have to be shut up to make it comply, good luck
PS they really are in some ways trying to help, as the BOV will decrease your fuel ecomomy and make the emissions heaps worse.
https://www.sau.com.au/forums/topic/162446-damn-cops/#findComment-3036261
i was told by my mechanic that if your BOV is 'plump back' as a pose to 'vent to atmosphere' it's perfectly legal. And that pod filters can be made legal if there are boxed on all six sides. I could be wrong though
https://www.sau.com.au/forums/topic/162446-damn-cops/#findComment-3054043
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
