I'm looking at buying a house so i need get a a more tame car :) for a while
This GTR won the SAU best R33 GTR award 2 years ago...
It currently has about 84,000km and about 20k on the engine...
It currently makes about 300kw atw on 18psi this car has virtually no lag its very very responsive...
I use it as a daily driver but its built to be a track weapon.
The car has been serviced by UAS...
CP Forged Pistons (20 thou oversized)
Carrillo Forged Conrods
SPS CARR Conrod Bolts
Tomei Cam Sprockets
Tomei 1.2mm Head Gasket
Tomei Gasket Kit
Tomei Oil Gallery Restrictor
ARP Head Studs
Sard 660cc Injectors
Bosch 044 Fuel Pump
NISMO Fuel Regulator
Z32 Air Flow Meters
Trust Sump Extension
OS Giken Twin Plate Clutch
NISMO Timing Belt
N1 Water Pump
JUN Oil Pump
NISMO Engine Mounts
NISMO Gearbox Mount
Trust Clear Cam Gear Cover
Cusco Master Cylinder Brace (painted black)
RacePace Custom Oil/Air Seperator - Mark II Design
APEXi Pod Filters
APEXi Power FC Pro
Turbosmart eBoost
Tomie 260 poncam's (needs to be installed)
HKS GT-SS Turbos
Port matched Exhaust Manifolds
HKS Dump Pipes
HKS Front Pipes
3" Cat
APEXi GT-Spec Cat-Back Exhaust
18x9" 5Zigen Wheels
265/35ZR18 Bridgestone S03s
Tein FLEX Coilovers
Tein EDFC Controller
AP Racing 6 Pot Calipers
Brand new 330mm DBA Rotors w/ aluminium hats
Ferrodo DS2500 Front (Road)
Ferrodo DS3000 Front (Track)
Ferrodo DS2500 Rear (Road & Track)
BF Goodrich Braided Lines
Motul RBF600 Brake Fluid
Recaro SR-3 Drivers & Passenger Seats
Genuine Series 3 Xenon Headlights
Brand New Nissan Under-Bonnet Pad
NISMO Bonnet Lip
NISMO Rear Wing Ornaments
N1 Front Bumper Vents
If you have any questions about the car please feel free to contact me on 0414 99 53 91
As for asking price i'm not sure what this car is exactly worth given all the work..
I'm in Sydney btw
I just saw the rules, i'd be looking somewhere in the 40's...
Edited by kabab
https://www.sau.com.au/forums/topic/162621-r33-gtr-1997-vspec/
  • Replies 44
Kabab,
I normally dont post in for sale threads like this, but I had to....
Man, that is one awesome machine - best, tidiest GTR Ive seen for a long long time
No doubt the new owner wont have to spend a cent on it, everythings been done that needs to be!!!
As for price - obviously its insured? Maybe similar price to the insured value?
Oh, as for my buying it, the mrs would...well....dont go there :)
Sweet ride once again mate,
Chris
Kabab,
Chris
Actually the cams need to go in its got stock cams atm.. I've got the poncams in the garage those alone will add about 40kw and give more mid range... Its fairly cheap to drop them in as well..
Its all ready for NOS to i have the bottle in the garage as well :happy:
Its insured for about 50k
Forget the misses :D
More pic's
Edited by kabab
ahhh Andrews old car....
I have seen this car in the flesh a few times and I can say it is one of THE cleanest 33 GTRs out there..
Andrew was a very anal....owner :) and im sure you were as well :P
Being a 32 and 34 follower I wouldnt normally consider a 33 but for this car I would make an exception :glare:
Goodluck with the sale, im sure the new owner wont be dissappointed
i drove 600km today - all the way to canberra and back with a BIG fat deposit to put on another car.
to cut a long story short - walked away very dissapointed.
so im back to square 1 - shopping AGAIN! - where in sydney are you located as id love to come and see your car?
Edited by 350z
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
