hey guys
i have an rb20 with the following mods:
-turboback exhaust (Hiflow cat)
-Pod filter
-turbotech boost controller at .7bar
-SAFC
i had the SAFC installed by a mate but i dont have an airflow guage to tell
me weather its running rich or lean. The settings at the moment are as standard
but i was just wondering if someone could post there settings up because i will be
getting a tune in the next couple weeks.
cheers adrian...
https://www.sau.com.au/forums/topic/162899-safc-settings/
dude get a AFM gauge and get it tuned .. On the forum I think someones flogging one for $20 .. Will let you know exactly how its running all the time.. and then you can also make sure the pro is right ..
and off course update every time you get a new part :D
https://www.sau.com.au/forums/topic/162899-safc-settings/#findComment-3023801
you need to be careful with the air fuel ratio guages as most of then are not wide band, to be able to see what your car is actually doing in terms of air/fuel ratio you need a wide band sensor in the exhaust and a guage that can read this, the standard o2 sensor in your car is not a wide band sensor,
https://www.sau.com.au/forums/topic/162899-safc-settings/#findComment-3024096
so your saying i shouldve paid 600 for a dr drift remap.
im better off buying a pfc arnt i.
At the moment im not up for massive gains just yet so ill see how it all goes.
PFC are about 1000 bucks plus there is install, tune etc. Im not quite sure about power gains for a safc but is should be noticeable. I still have not got around to getting mine tuned yet.
https://www.sau.com.au/forums/topic/162899-safc-settings/#findComment-3026400
the reason y i bought one was because it was hesitating and it missfired so i was
told to get an SAFC. after gapping pluygs at .8mm everything seems well.
i had a read on a few threads on here about tuning the safc n most ppl say they gain anywhere between 13 and 25rwkw with the correct tune.
the more the better i guess
https://www.sau.com.au/forums/topic/162899-safc-settings/#findComment-3026424
well i got my safc tuned 2day and this is what came up:
Mods:
-turboback exhaust with hiflow cat
-pod filter
-turbotech boost controller at 10psi
-SAFC
Before:
max power: 130.1rwkw @ 6324 RPM
max torque: 506.7Nm @ 5497 RPM
max M.A.P kPa: 179.9kPa @4141 RPM
After:
max power: 137.2rwkw @6344 RPM
max torque: 538 Nm @5082 RPM
max M.A.P kPa: 177.7kPa @3792 RPM
he said that i gained 7 rwkw just from the SAFC and without touchin the boost
for safe reasons. He didnt want 2 up the boost because i still had the factory cooler.
Would u guys say that this was a successful tune or not?
also....
if i decide to get a FMIC and up the boost will i need another tune or will it be ok?
cheers guys...
https://www.sau.com.au/forums/topic/162899-safc-settings/#findComment-3049556
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
