Selling this parts off my GTR done genuine 34000klm all are in perfect condition
stock turbos+stock dumps $800
stock injectors+fuel rail+reg $400-----SOLD
stock fuel pump $100-----SOLD
stock radiator $60
4 x nismo 550cc injectors to suit SR20 $400
standard air flow meters $300 for the pair
Parts can be picked up at CRD or northern beaches or on the way to gosford, or i can post them at the buyers expense
Edited by NIS.26L
  • Replies 41
can you pls pics of the turbos thanks.
sorry i cant get photos until i pick up the turbos but there isn't much to look at they are r34gtr roller bearing turbos with dumps and actuators
email the pics to [email protected] and I will host and post them for you...
also, if they are still available, would you seperate the turbos?
thanks mate i have emailed the pics
do you want to email pics of the rest of the stuff as well... I'll put it up in here for you.... or otherwise... just open an account at www.photobucket.com and upload your pics there.
they will then give you the links for the pics so that you can put them in your posts the same way I just did above :)
Did the pump go?
I'm still interested if the sale didn't happen :yes:
i havent pick up the pump from CRD yet but it appears to be sold if not i will post it up
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
