Guest Yoda
Are roll cages really illegal? I've been looking for the law that says that they are, but can't find it. I know they have just made them compulsory for utes (etc) that want to carry passengers in the back, so maybe they have changed the whole roll cage law. also, it might vary from state to state. i'm in WA at the moment, and think that i should be able to have a roll cage. I heard they are illegal because they cant use the 'jaws of life' on them to cut you out in case of an accident. I figure, if my car is so mashed they need the jaws of life even WITH a roll cage, there aint gonna be much of me to cut out.... :)
any thoughts?
https://www.sau.com.au/forums/topic/16298-roll-cages/
from what i know of this is in melb roll cages are legal to a certain extent but jap spec ones are not legal preety sure
alot of jop ones bolt onto the floor
the australian standard ones actually connect through the dash into the firewall and are a certain size 40mm thick or somthing while jap ones are 30mm thick.
no one is stoping you from putting one in if its a jap spec one but if you want legal one for racing etc. it will cost ya baout a 1 k to get one made and fitted. but if its for normal driving dont worry about it and if you really want one there are heapz of second hand jap spec ones around =)
Cheers
https://www.sau.com.au/forums/topic/16298-roll-cages/#findComment-334105
YODA
In WA they are illegal to have a FULL Cage in the car.
However, you are able to get a permit for a half cage or roll bar as they call it. At present I run a full 6 point cage in the car and haven't had any issues with the law at all and it is clearly visible with the huge thick crossbar through the rear window of the car (around 80mm thick with padding).
I have had cops sit on my tail at both traffic lights and on the roads and haven't pulled me over. They have even had a good look at my car while parked at a motorsport event with me there and didn't bother to question it.
It's basically illegal due to the fact that you can smash your head into the bar in an incident and cause yourself damage, but as I see it, its better to have one in the car for safety sake although I hope I never have to use it.
It greatly helps in the handling of the car also which is the main reason I have left it in. If you want one in, you risk a yellow sticker but thats something you have to live with!
Shaun
https://www.sau.com.au/forums/topic/16298-roll-cages/#findComment-334241
Guest Yoda
Originally posted by RadiuM
YODA
Shaun
https://www.sau.com.au/forums/topic/16298-roll-cages/#findComment-334337
1> after looking at it today, its about 60mm thick without padding.
2> it reduces the car's flex when cornering quite dramatically, im sure the front and rear strut braces also help in keeping the car rock solid.
3> came with the car. :)
my cousin has a 32 cage that I think he will be selling as his son got a yellow for it in his R and he said they wont be bothering putting it back in. So if you have a 32 and are looking for one I could ask him.
Shaun
https://www.sau.com.au/forums/topic/16298-roll-cages/#findComment-335850
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
