Skyline R32 Gtr Bayside Blue wrecking, with some aftermarket parts
Link for 1st car http://www.skylinesaustralia.com/forums/in...158895&st=0
*Some aftermarket Aluminium cooler piping
Will post small items interstate
PM with any Q's or email [email protected]
Located in greensborough, Melbourne 30mins N.E. the city
Mob 0417 125 253 Elliot, PLZ CALL AFTER 4pm During week days as i can't answer calls during work, Any time wkd's.
Edited by KLR32
Do you know what clutch it is yet?
Also might be interested in the trust pipes, just fom end of dumps to cat same style as hks pipes right?
might be interested in ab-flug steering wheel got pics? des it have a boss kit?
And rear spoiler how much? any damage?
I will reply to all Q's tomorrow and upload some new pics of bonnet, ab-flug wheel and cooler piping.
Cheer Elliot
Hey Elliot i spoke to you tonight
Need the passenger side suspension links:
- upper link
- upright
- lower link
cheers, marcus
Complete car minus Eng and G/box
*GTR bonnet with bonnet pins, No dints what so ever! $550
*GTR Rhs frnt guard No dints! Excell con'd beside 2 spots where paint has chipped off. $300
Aftermarket Parts-
*Ab-Flug Steering Wheel $60
*HKS Springs $250
*Full Veilside Bodykit (On ebay Atm)
*Veilside side skirts SOLD
*Jasma cat back $350
*Tomei 310km/h speedo needs clear cover swapped as there is a few scratches $500
***Parts from 1st car
*Trust front pipes $200
*Full set of Floor Mats in good con'd 5 mats in total $150
*Blizt Boost $50 and oil guages $80 (Both need wiring with plugs)
*Twin plate clutch
Is that a black bonnet there with bonnet pins mate?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
