phoned sliding performances couriers: couriers please, and i asked them if my turbo was sent out from qld on monday. they told me i should have had it by wednesday at the latest delived to victoria. im furious. i need a tracking number. DO NOT. I MEAN DO NOT DELETE THIS THREAD!
https://www.sau.com.au/forums/topic/163361-still-waiting-for-slide-hiflow/
3 days is about average on normal mail, express 1-2 from qld, i'd start worrying if it's not there by tuesday week (can't expect much movement over easter).. I'd give them a call and get a tracking number, should be able to see exactly where it is if they sent it via aae, auspost, DHL, toll priority and a few others.. i'd be hoping they didn't just throw some stamps on it and send it your way=.=
Closed
R33GOD, as per my post in your Victoria thread, please do not open multiple threads about this, it is completely unnecessary and will achieve nothing.
I don't know what happened to your original thread but lets just stick with the one thread in the General Automotive Discussion area as this will no doubt get the best exposure.
Thank you
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
