Can someone be so kind as to inform me of the largest 18" rims that will fit under a stock series 1 stag. It is still in lift kit mode, so some form of lowering is also going to happen as well.
I am looking at some ford au/ba rims and I'd rather find out what would be pushing it before I go see any.
AFAIK standard offset is for s1 stags is 35, yes?
I have looked searched through some other threads but most of the stuff appeared vary a fair bit and a lot was for series 2 stags.
um
depends on how much massaging you want to do
I had 18x9 +0 front
18x10 +20
if you get an 18x10 +10 it will clear with almost 0* camber, but you need a alrge fender roll qhich i didnt want to do
However if you go with 18x9 +10 or +5 it will sit almost the same ( a few MM difference) with 20+MM more interior room so you wont hit your coilovers like i did
on the front you can afford to go with 10s +10 or so as long as they clear brakes if you have tension rods ...but id reccomend a PS cooler if your going to...as 10s put a huge strain on your PS system
For the rear two arms are a must
Toe Arm and camber arm
if you can get the other one (traction i think its called....i dunno) then get it
Use all S14 model arms, you can find them for 90-150 each arm depending on where you look.....
forgot to add
if you go lower than 18x9 +0 you will need to heavily roll your front fenders as well.
i put a slight roll on mine, but it has too much camber, which is why i went with an 18x9 +20 all around so i can just space the rear a little bit.
this is what it looks like with an 18x9 +0 18x0 +20
I'm not looking to fill it out to the guards absolute limit, I just want some decent rims that aren't going to cost my nuts to replace the stocko ones.
Hrm I have 225/50R16 tyres on the car, if I go to 245/40R18 thats surely going to put the speedo out somewhat?... is my real speed going to be faster or slower than the speedo is indicating?
Also after looking under the arches, the rear will be fine, but the front has some suspension part that sits within a few inches of top of the tyre, is that going to be a problem at all?
Last question, +38 offset as opposed to the +35, that will bring the face of the rim slightly closer to guards? or is it going the other way?
Edited by rubba
ah I have no idea, sorry. I have 18's on mine, but no idea on the offsets bla bla bla cause I don't know what 'offset' is :sick:
It reallyhelps if you are of the opposite sex? LOFL
PS> Nor do I
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
