  • Replies 63
Guest drift_me_silly
power porting standard plenums can give substantial gains...i believe for the cost this is the best compromise. outright power is only of use on a the track, drag or circuit. street requires a compromise. go book a sesh at the flow bench...it's there the results can be seen.
Yer, but don't forget the advantage of drawing the air through about 1m less of piping by taking it directly from the front of the plenum. Always makes more sense to me.
I got like PLENUM====
..................FMIC
I mean u prolly know this already.. but to me.. this makes more sense...
PLENUM
=FMIC
I just wish i had the money to do it to mine.
Trust/Greddy/Grex/ same shit... there is no OR involved...
I think trust have a big market outside Japan, it seems in japan other companies seem to try get away with flowing the std pleneum. And prob would be worth them making something as pretty as the Trust/Greddy one? Americas market is more along the lines of Buying off the shelf products where i think Trust makes most of its money and what they base there cars and records on...off the shelf products. If you want something which works without the look, im sure you know where to go.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
