Hi Phil, the best way to find out where your membership is up to is to pm shell on these forums she will be able to confirm.
As for donations, the forums are seperate to the club, you will need to contact prank about that ;)
anyone have any news on my membership application at all? Sent in a week or two ago *scratches head* can't exactly remember when.
Also, the donor status thing. Donated the max ammount, yet no donor tag?
Phil, yep i got your form out of the PO box on Friday... will most likely be sending your stuff next Friday :D
MAR55S, you can stop ranting :D your card is made and will be on it's way this week, yours too satanic.
as for the list, i can't edit the post atm for some reason...but you'll be on it when i can.
  • 5 weeks later...
I've fax and payed direct to the SAU bank account. Can someone get me access to the members forum cause I want to come to the Putty Road cruise. Need details on the meeting point.
  • 4 weeks later...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
