Had this topic in the sus section but got no help so I thought I'd try here
if I need a cefiro cross member to put a rb in a S13 as it sits the motor lower than a 32 cross member
could I fit a cefiro cross member into a 32 to get a lower centre of balance i.e better handling?
Im selling my sil and getting another 32 again soon
Im already going to swap the rear craddle to a non hicas s13 one
also pulling the motor out to swap for 25det so thought I might as well swap the cross member if there would be any benefit
waits........
From memory it sits 2.3cm lower and does clear the bonnet this is with a 3025 though.
You have to use the RB25 cross over pipe as the blow off valve on the 32 cross over pipe hits the bonnet regardless.
RB25's do not have clearance issues going straight into R32's.
The 3025's do and will mean you cannot use a strut brace that is not modified or goes around the back of the head..
There was not a standard bonnet on this one it was a carbon vented bonnet so the relative hight difference between the 2 i am not sure on compared to standard.
We have always used modified vented bonnets when doing conversions to help get rid of the heat especially with S13's doing RB conversions. :thumbsup:
Using a Greddy copy or original plenum will solve all possible problems.
For $250 for a copy Greddy plenum you cant go wrong considering that is how much the cross member will probably cost.
if u are using the stock r32 bov on the r32 crossover pipe than the bov clears the s13 bonnet no problems (yes i know who keeps the stock bov)
I can assure you my Onevia's stock blow off valve used to touch. :)
RB20DET equipped.
Sorry to hijack here guys,
I have a laurel (C33) crossmember which I have heard is either the same or does the same as the A31 cefiro ones in terms of placing the motor in an S13. Can anyone confirm this?
Also, when mounting the RB25DET in an S13 my understanding is that I will need to use the engine mounts and engine mount brackets off of an RB20. Can anyone confirm this is correct as I am going to order some nismo mounts for R32 GTS-t soon. :w00t:
Thanks
So basically I would order a set of nismo mounts for R33 GTS-t if I was using the R33 engine mount brackets and I would order R32 GTS-t nismo mounts if I was using the R32 brackets?
Is there any height/placement difference between the two? I can swing either way so if one is better than the other then I would like to know :w00t:
Both mounts can be used.
To modify the engine brackets simply oval the pilot holes for the bolts that screw into the block so the sump sits closer to the sub frame.
Just keep in mind the lower it sits to the subframe the lower it sits to the ground.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
