hey, ive got a new front bar that has the grill moulded into it so no longer have a use for this.
its white and very well made. its got a sticker on it that says it was made by blitz bodykits.
pick-up only. im located in south east brissy
$100 ono
this isnt my car but it looks kinda like this
https://www.sau.com.au/forums/topic/163552-r33-gtr-style-grill/
$100 ono
Are you able to post any flix of the actual front bar you're selling,what condition,any cracks scratches etc.? Or PM me with details interested in possible pick up this wkend.
CHEERZ...HUNTZ.
  • 3 weeks later...
