Here is the Excel file I used to map my Fuel and ignition tables. I am sure some of you guys out there can get some use out of it. I recently had Mick from subzero Dyno my car. You can clearly see the fuel he took out of it at PFC load Value 15-16. The car was being retuned at 1.10bar. The Ignition points around 15-16 need to be trimmed at peak torque to reduce detenation. Did make 225kw tho. When the timing is retarded I think it will negate the extra boost and all I`ll end up with is a slight increase in mid range power only, probably actually loose some up top.
https://www.sau.com.au/forums/topic/16374-power-fc-chart-mapping/
  • Replies 58
HKS Super Dragger Ex
HKS Dump Pipe
mesh removed from A/F meter (stock r33)
Apexi Air filter /partitioned off
Greddy 28c tube and fin front mount intercooler
Heat wrapped turbo to cat*
*cat in pipe
heat wrapped intake pipe
Power FC
HKS solid twin plate clutch
Cut out front bar
Oil air seperator
Bosch Motorsport fuel pump
Motul 5w40 oil
Nulon G70 with auto trans fluid in the gear box
1bar to 1.10bar boost
HKS EVC4
Pureone oil filter
Stupidly huge fuel filter
BPES7??? plugs 0.7mm
BP ultimate 98 Fuel 1bar- with octane booster for 1.1bar,also another 2degrees added with octane booster.
I`ll modify this post if I can think of any more
Originally posted by Steve
225kw with stock turbo!  1.1bar with stock turbo!!!! you're a very brave man:)
Your right on the money Steve, I only get near those figures with a healthy dose of octane booster and I still get a minor ping. I`m taking it down AIR for the next street meet. Fingers crossed I can get through another 6 passes.
Thanks boostd useful info.
I actually leaned out the fuel map at idle to try and reduce exhaust fumes (I don't have a cat fitted). Hunts a bit now (I took the AFM screens out also), but less likely to gas myself whilst idling in a semi-closed garage.
I'll drop my maps in for the RB26 and post here also.
Anyone else got RB26 maps?
Its Greg from base. What do you reckon try loading your figures into my car. Where could I go wrong. Our cars have the same mods virtually. Mine has only had one tune for an hour on a 43degree day. So there is nothing to loose. I am planning a turbo upgrade in the near future so it will have a retune then.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
