  • Replies 133
Guest INASNT
Originally posted by raist60
You hope ;)
I seriously suggest you speak to someone about rolling past 250rwks on standard bottom end.
forget pistons, short penned rods, slightly ported head, 264 duration cams, high strenght valve springs, metal head gasket, highflow oil pump, nitrided crank (x rayed for micro cracks also) etc will go in if she blows. I was gonna do all that 2 but the tuner said leave it and if it finially blows then do it. :D
Damn dude!!! What a weapon :D I bet you can't wait ;):D
Guest INASNT
that stuff will only happen if i blow my engine!
I hope it holds together for atleast 6 months so i can save up the $$ for that stuff!
A race port on the head which flows about 60% better costs $2500 alone
Guest INASNT
Originally posted by T0nyGTSt
When you put it like that... ($10,000+) I tend to get upset a bit :-(
Ar ****... $2,500 - $3,000 should finish me off.
T.
hey its just $$. And u r only young once. For me it was either spend alot more $$ and get a 96 GTR/350Z or even struggle and get a 2000 R34 (have to live on bread and water for a long time) or mod my car. Modifying my car was the cheapest option. I will get the GTR after the house coz u can borrow it as an addition to your house load and pay home loan interest rate which are very low
There is a method in all my madness!!:D
Race port for 60% better flow and $2.5k, dude you really need to take a look at who can do the work for you. Adelaide price, done on flow bench, 70% improvement cost $700. Hillsmotorsport quoted me $895 for a full port including extrusion hone. Perhaps you need to shop interstate, but I am sure there must be better deals around melbourne way.
Guest INASNT
$700 is farkin cheap! I got the heads done on my 250ci x flow cortina engine and it cost me $1700 5 years ago!
Alot more work to be done on a 250xflow, but that still seems a bit dear - have you thought of just getting an extrusion hone done? the stock heads do work pretty well from the factory. Even may be a bit questionable if you need to do valve springs, unless you intend pushing the redline right. I think that alot of shops try and sell you stuff that you really dont need. As you would have realised by now, you can just keep pouring in the dollars until the cows come home.
There must be someone on here that has had some head work done in melbourne, it would be interesting to hear what sort of results have been attained and at what sort of cost.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
