Hi guys,
After a stereo installation on my R33, my constant wire seems to be dead. It had also caused my clock to stop working. At first the clock was just resetting back to 1:00 but now it doesn't show at all.
Any idea if this is a fuse?
Can anyone recommend a decent auto electrician or car stereo installation place in inner Melbourne / Prahran area to fix this issue and install the stereo?
Regards,
David.
Edited by McCracken
sounds like you grounded that constant wire and shorted a fuse... its pretty easy to fix, open up the fuse box and look for one that has broken...
it also sounds like you stole the constant wire from the clock... you should make your own from the battery...
tee hee, your welcome :(
i have asimilar problem except i couldn't get my stereo to work ... the clock is not working and i have checked the fuses and none are blown and clock still not working any ideas guys i want my clock and stereo lol
did you check your power wires? im a little drunk, so im not sure about anything, but check your power wires... run some wire straight from the battery to the 12V line on your headunit... if that works, then your power wires are Effed in the A somehow... run new ones...
you have to try both 12V and Acc, the headunit wont turn on without the Acc one attached... so if you chuck a 12V constant on that, and it works, it means your Acc is f**ked somewhere along the line...
either wire or fuse... run a new wire from the fuse to the head unit, if that works, that side of the power works... if that doesnt work, the 12V line to the Acc fuse is f**ked...
trial and error is fun :(
be careful :rolleyes:
also, more info helps sometimes :)
also, i hope that made sense, cause im not proof reading it...
Edited by DRD-00F
its possible... but i think everything in that cluster uses the same fuse/power lines... your better off getting a long cable and going straight from the battery...
but try it, ive never had that exact problem, so give it a go...
man im getting jipped :rofl: my fuses are in the engine bay...
but yeah, theres 2 lots of fuses... when we say 'check fuses' we mean both lots... one is above your right shin when you drive, the other is either in your engine bay on the left (from drivers seat) or in the boot?
Edited by DRD-00F
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
