Hey guys, just looking for a quick sale!
R33 Series 2 Carpet Complete Set A1 Condition $200 + Postage
Z32 AFM with Plug Suitable up 500Hp $250 + Postage
Cheers
still got the z32 ? if so im guessing with plug u mean plug to suit r33?
do u know what voltage it ran in ur r33?
cheers
Cheers
ill take the mats thanks
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
