ok im looking at going engine management and powerfc is looking pretty good, can get it at an awesome price, is the boost controller a wrothy addition ? or is another ebc or bleed valve a better option ?
i currently have
pod
exhaust
safc (will go once i get ecu)
FMIC
can anyone recommend another ecu that could be better ? i'd prefer a full replacement rather than a piuggy back, but if a new ecu isnt worth it yet please tell me as i wanna get performance outta what im paying :)
cheers
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/
  • Replies 65
Can u get by with a new turbo *without* full aftermarket management?
I've always thought it was mandatory, but somebody Nath said he spoke to said you might not if you had something like the S-AFC.
I'd imagine you would have problems running an external fuel pump and things which u would need as well without a new ECU ?
Would it depend on the turbo? If u had a highflow T28 housing would u get away it ? Or is it the bigger turbo wheels and ECU boost restrictor that will get ya?
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-336568
Hi predator666, speed limiter, overboost limiter and ignition timing adjustment are problems not fixed by SAFC (fuel only). If you add up all the bits you need to do the job properly, a Power FC is cheaper.
The standard ECU will run any pump, no tricks there, the ECU turns it on when you turn the key and turns it off when you turn the key. If the engine does not start or stalls the ecu turns the pump off so you don't get fuel everywhere with a leak or in an accident.
Some pumps draw a lot of current and the standard wiring is too small. So you may need to run a relay with direct power feed from the battery/alternator to give it sufficient power, nothing to do with the ECU though.
I have seen plenty of Skylines with bigger turbos running the Standard ECU and piggy backs, running OK with good max power. But they never seem to run as "nice" as ones with Power FC's, more lag, less throttle response, soft idle etc. They also tend to be a bit unreliable as they have added wiring and plugs which (depending on workmanship) sometimes fail and cause all sorts of time consuming problems.
Hope that helps
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-336610
INASNT, u get from greenline by any chance ? i got quoted $1469 for the brand new powerfc (latets model) with hand controller to my door, and around $1800 if i want the boost controller in it too
is the bost controller worth it ? or are ther better/cheaper things to use with the powerfc ?
and would you guys recommend the powerfc for me, or think something like the haltech e6k or the microtech are a better choice ?
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-337811
Guest INASNT
nope nengun! $1300
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-337846
Guest INASNT
greeline is cheaper, negun said the powerfc = 2nd hadn and the controller is new where as for $1468 i get both BRAND NEW with 1 year manufacturer warranty from greenline, and if i want the boost controller its $1895
what u guys think ? pounce ?
u can get used pfc,hc and boost controller for $1400 from nengun
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-338622
Guest INASNT
hmm i'd prefer it all new, ant that mnuch more, i might consider fc + hc nerw and s/h bc... hmm
inasnt what boost controller u using ?
with ecu's second hand works fine as electronics dont have any stresses or forces applied to them so there is no wear and tear on them.
I am getting post prob a blitz dual sbc or trust profec B, not 100% sure as yet. I can get either for around $500
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-338678
i do ps2 and xbox mods, EVERYTHING electrical has wear and tear man... especially something in a car...
and are the powerfc bc's the same as the profec b'as etc ? as gordo's didnt look like it had stage settings like the avcre, rpm step by step control... does the fc bc have it ?
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-338686
Guest INASNT
dont know what the pfc boost controller has on it, but its controlled off the H/C and its a very basic display H/C display.
U are safer buying second hand electronics rather than mech parts. All the nengun stuff comes with a warranty so its all good, and the 1 i am getting has already got a mad tune in it! :P
https://www.sau.com.au/forums/topic/16419-apexi-powerfc/#findComment-338692
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
